File Request I NEED THE BIOS HP ZBOOK 15U G2
send original bios backup
there is a button below : Attach Files
try attached file
HP ZBOOK 15U G2
  • HP ZBOOK 15U G2.zip
user7584
CARLO
if I put the original Bios that I sent to you the computer will turn on View but after 30 seconds it will turn off
exact 30 seconds ?
or different times ?
this problem i think is not related to bios
the bios files which i sent are OK and working
please check other parts of the board too
user7584
CARLO
the Bios that I downloaded from you does not even turn on an LED, while with the customer's Bios the LEDs turn on, but it displays and then goes off, so I agree that the defect that goes off may not be related to the Bios, but that the Bios that you have provided is not ok because the LED does not turn on either
  • 15U G2.zip
user7584
CARLO
ok Thanks Perfect This works perfectly and the computer does not turn off as before thanks for everything to the next
